1931-32 "Pitchfork" info
- auburnandyscar
12 Jun 2015 01:21 #29731
by auburnandyscar
Check out my build at:
www.1932auburnsedan.com
Replied by auburnandyscar on topic Re: 1931-32 "Pitchfork" info
Thanks Randy!!
11 Jun 2015 15:06 #29726
by RandyEma
Replied by RandyEma on topic Re: 1931-32 "Pitchfork" info
Hello. Yes they were chrome. r
- auburnandyscar
11 Jun 2015 02:33 #29725
by auburnandyscar
1931-32 "Pitchfork" info was created by auburnandyscar
Hi all,
I have been able to obtain an original upper "pitchfork" grille insert for my car. Being 'potmetal' (zinc) it is in rough condition from all of the years, dirt, and off gassing of the 80+ year old zinc. I have done some sanding/rubbing/polishing to get portions of it to shine up pretty well considering its' original (to me) condition.
My question is were these originally coated/plated? I have not seen ANY evidence of copper plating over the original metal, if they were originally just nickle plated, did the nickle go straight onto the zinc?
Additionally, was chrome plating that expensive/tough to do in the 1930's? It seems as if 'everyone' went with just nickle plating and called it "Good enough"?
and yes, I am aware of the chrome plating process, I just cannot figure why you would do 95% of the work to prepare a piece, and then "Lay down" and not put the hard chrome on it....
