American LaFrance V-12
  • jpsands
  • jpsands's Avatar Topic Author
  • Visitor
  • Visitor
07 Jul 2004 05:34 #1918 by jpsands
jpsands created the topic: American LaFrance V-12
Eighteen months ago I acquired an American LaFrance V-12 engine which is identical in most details to the Lycoming V-12 made for Auburn.
The visible differences are the dual ignition and the carburation, but there may be other, less visible, differences.
Does anyone have any literature on this engine? Is it potentially convertible to an Auburn V-12?
Were any of these converted for Marine use?
John Sands
07 Jul 2004 06:01 #1919 by Lycoming-8
Lycoming-8 replied the topic:
Glen Pray in Broken Arrow, Ok (918-251-3161) can likely help quite a bit. He has had several and used one to power the "Duesenberg" Phaeton that he built some years ago. The big 12 looks quite at home in the Duesy engine compartment by the way, as it resembles the twin cam J engine. Believe that the heads are the primary difference between ALF and Auburn V12.
'31 Auburn Coupe
  • Auburn/Cord Parts
  • Auburn/Cord Parts's Avatar
07 Jul 2004 18:38 #1922 by Auburn/Cord Parts
Auburn/Cord Parts replied the topic: LaFrance V-12
Yes, the 1938-59 V-12 LaFrance engine appears the same as the Auburn V-12 to teh average person. You realize that they range from 491.2 to 526 cubic inches. You cannot completely disguise one to be identical to the smaller 391.2 Auburn V-12. They won't run as good when fitted with the small venturi Auburn carburetors and the restrictive Auburn exhaust. They do have inserted rod bearings. Some have protrusions on the block casting that cannot be removed. If you just want to build a fun Auburn that's a real runner, these LaFrance engines are the ticket. Most fire apparatus sales companies have a complete LaFrance truck or two sitting out in the weeds. You can get them very reasonable. None had marine use but Lycoming did build a much larger 12 cylinder marine engine around 1,000 cid.
Stan
  • jpsands
  • Visitor
  • Visitor
07 Jul 2004 19:56 #1923 by jpsands
jpsands replied the topic:
Good information!
I guess another problem might be adapting the engine to an Auburn transmission.
My engine has a distributor in the normal location and another attached to the rear end of the generator. This latter could be removed, and the two-spark plug heads replaced with single sparkplug heads. This might make the engine more practical to maintain.
John
Time to create page: 0.063 seconds
