1931 898 spark control knob operation help
04 Jul 2016 04:07 #31343
Replied by mikespeed35 on topic Re: 1931 898 spark control knob operation help
Here is the info. from the A.E.A. Tune-Up Chart. "Stationary breaker contacts to open at 12 1/2 degrees (3 1/4 flywheel teeth) before top dead center for No. 1 cyl. Manual spark lever fully advanced" Manual advance is 7 1/2 distributor degrees. Automatic advance is 13 1/4 at 1300 distributor degrees. Remember distributor degrees and distributor RPM's are 1/2 engine RPM and degrees! Before doing all this make sure the points are synchronized. They are synchronized at 45 distributor degrees. Breaker gap .018 to .024. Dist. machine is best choice but syn. tool also work relatively well if done carefully. Good luck.
Cordially Mike
Cordially Mike
- curtiss
03 Jul 2016 22:21 #31339
by curtiss
Replied by curtiss on topic Re: 1931 898 spark control knob operation help
Brad, did you ever figure this out? I am in the same place trying to figure out what position I should time in. Do you push it in and leave the pull out at a retard or do you adjust it whole out and use it as the manual advance. The book says there is a manual advance and the pull switch is the only way I can think of having that work.
- JOEL GIVNER
30 Oct 2014 15:28 #28441
by JOEL GIVNER
JEG
Replied by JOEL GIVNER on topic 1931 898 spark control knob operation help
Brad,
In looking at two different Auburn operating manuals (1926 8-88 and 1930 8-125)
under operating instructions, starting the engine......both manuals state to "retard spark lever (left lever on steering post) by drawing it halfway down"
After engine starts, advance spark lever upward as far as it will go (driving position).
Mike's L-29 is essentially the same as the Auburn 1930 8-125
Joel
Joel
JEG
- Brad Hoskins
- Thank you received: 11
30 Oct 2014 04:32 #28437
by Brad Hoskins
31 8-98 cabriolet
Replied by Brad Hoskins on topic 1931 898 spark control knob operation help
Does any of the Cord literature offer an explanation of the usage? I'm pretty sure I get it but I am still curious about the lack of any 'official' description since the Auburn manuals did cover the rest of the controls.
In keeping with your comments,
I did find this comment in the 11/64 club newsletter article on V12's
gauge, and water temperature gauge. Controls included the throttle and choke, manifold heat control and a spark control to retard the spark from the setting of the automatic advance mechanism. These
engines start easier if the spark is retarded.
And this from the 7/81 newsletter on L-29's
D) Ignition Timing: Spark control full advance
(pushed IN) Distributor set so contact points are just
breaking for #1 All engines are set at 12° to 15° BUDC,
or 4 to 5 teeth before flywheel is at top dead center.
Just nothing from the factory!
As a word of caution for anyone trying to use the 1927-1941 National Service Manual available on this website restorecarsclassifieds.com/wiki/ ... .php?n=249 ( which is an interesting website with some really good scanned information) the procedure for setting the timing for 1931 is wrong and the procedure for 1932 is correct as far as positioning the distributor goes! Thus my head scratching! Too much internet isn't necessarily a good thing especially if it involves bad information from 1941!
Brad
Brad
31 8-98 cabriolet
29 Oct 2014 03:44 #28428
Replied by mikespeed35 on topic 1931 898 spark control knob operation help
My L-29 Cord has the same setup. I retard the spark for starting and then advance it and leave it alone.
Cordially Mike
Cordially Mike
- Brad Hoskins
29 Oct 2014 03:05 #28427
by Brad Hoskins
31 8-98 cabriolet
Randy
As I understand it, they have both the automatic advance (centrifugally operated spring weight system in distributor) and the manual control on the dash.
Was the dash spark control just there to balance out the dash arrangement or did it actually serve some purpose .
If I my understanding of the operation of the system correct, then all I can think of is that it's function is solely to manually retard the spark to allow for safe hand cranking of the motor. I just think it odd that the manufacturer would supply a knob and offer no advice on what it is there for. Perhaps we are too accustomed to 200 page owner manuals that describe what a door handle is for!
Brad
Brad
31 8-98 cabriolet
28 Oct 2014 15:07 #28420
by RandyEma
Replied by RandyEma on topic 1931 898 spark control knob operation help
It has an automatic advance . R
- Brad Hoskins
28 Oct 2014 05:37 #28417
by Brad Hoskins
31 8-98 cabriolet
1931 898 spark control knob operation help was created by Brad Hoskins
Trying to set the timing on the car and just wondering if Auburn ever supplied an explanation of the spark control in any of their literature. I've looked at both the Service Manual and the Operation Manual and I swear there is no explanation of how to use the spark control!
I'm from the Model T world where the spark control lever is always 'stored' in the fully up position - which is fully retarded. Three teeth down to start and then move it further down once started but not so far as to make the exhaust glow red!
I would equate that with the Auburn spark knob being fully retarded when it is fully pushed in and would have assumed that you would pull it out to advance the timing.
However, with the Auburn counterclockwise distributor shaft rotation, a full manual advance of the spark would result in the distributor fully rotated clockwise in the distributor base slot.
To me , this means that the distributor is fully advanced manually when the knob is pushed all the way in and pulling the knob out only retards the timing.
Do I have this right?
If so, was the spark control meant to be left alone and only there if you were crazy enough to hand crank the motor and wanted to avoid breaking your arm with a backfire?
Was this so obvious in 1931 that it didn't warrant mentioning in either manual?
Brad
BTW this forum is a wealth of information and, had I searched for 'spark' before trying to adjust the timing by the 'oil pump removal method' ( after determining that the shaft is 'keyed' to fit one way only), I would have discovered that there is a screw in the distributor end of the drive shaft and it actually serves a purpose. Another little missing tidbit from the Service Manual.
( it wasn't too bad as I had the pan off already anyway!)
forums.phpstack-1081784-3880776.cloudwaysapps.com/phpbb2/viewto ... ight=spark Thanks to Ken for that info!
Brad
31 8-98 cabriolet
