Ignition Points
- Auburn/Cord Parts
09 Apr 2004 15:55 #1562
by Auburn/Cord Parts
Replied by Auburn/Cord Parts on topic Ignition Points
We stock Delco dual points and ignition parts for all years of Auburns. They fit in 3 year cycles in most cases. 1928-30, 1931-33 Delco, and 1934-36 Autolite 8 cylinders. You must be careful as many are incorrect and a lot of the parts books do not give correct data for our cars.
Stan
Stan
- Mike Dube
09 Apr 2004 01:51 #1561
by Mike Dube
8-100A
Replied by Mike Dube on topic Ignition Points
You can get a distributor cap @ Napa that will work on the GU engine's Delco distributor, but it won't work with the plug wire loom. It also fits straight eight Buicks.
8-100A
- samsonized
09 Apr 2004 01:46 #1560
by samsonized
Replied by samsonized on topic points
the points you buy at a napa store have to be modified to work they are not correct. the cap is also different
- Al Hatch
08 Apr 2004 19:59 #1558
by Al Hatch
Replied by Al Hatch on topic Ignition Points
John,
Try going to your local NAPA auto parts store. I know for a fact, that they can get point, condensor, dist. cap, etc. for the '34-'36 6&8 Auburns. Althorough I am not an Auburn authority, I don't think there is any difference in the ignition system of a '33 8 to that of a 34/6 8. I also picked a spare coil while I was a the NAPA dealer. The dealer in Auburn, Indiana told me he stocks up on the 6-volt stuff just before Labor Day weekend and I got to tell you the prices are very reasonable. Good luck.
Al Hatch
Al Hatch
- samsonized
07 Apr 2004 11:10 #1552
by samsonized
i have 10 new dual sets i just purchased still in the box. each box has a set of two points in it <a href="mailto:[email protected]][email protected][/url]
- Mike Dube
07 Apr 2004 00:31 #1546
by Mike Dube
8-100A
There was a guy selling "half a set" on ebay recently. I pick mine up where I can find them, swap meets etc. Stan Gilliand may be able to help you.
8-100A
- John Trittschuh
06 Apr 2004 21:06 #1544
by John Trittschuh
Ignition Points was created by John Trittschuh
I will soon need to replace the points for my 1933 Auburn Phaeton 105A ignition system. Just replaced the wiring. Where does one get these points? Are they something from local parts store or do I need special ones? Incidentially, just got an 8 Volt battery and it makes a world of difference for starting. I'm told by the battery sales people to use a 12 Volt charger for this but use manual charge for short (4 hour) charge time, correct? Can 8 Volt battery be left in car for show judging or do I need to switch back to 6 Volt for that to avoid loss of points.
