851 SC Fuel Gauge
- morrisgauge
- Junior Member
www.morrisgauge.com
One problem I ran into was the air tube accumulated some white phosphorsesence that blocked it up. Not sure why. Seems like a crude system to begin with...
- Rogerlearmonth
- Junior Member
I hear what you say. The stick idea is a good one. It?s one of those things. The gauge and sender are there and supposed to work so it would be nice to have them operational.
Roger
- Rogerlearmonth
- Junior Member
Unfortunately, from a tank point of view my car is a BT Speedster. From the geometry, I assume there is no access to the unit in the tank without dropping it, or is there?
Roger
You will be able to see the tubes coming up from your pickup unit.
- auburn653
Can you post the specs? I have a spare tank unit that I don't know what it fits for sure (came with mixed parts including 31-36 parts). I know it has general shape, etc. of the one in my 35, but, it's been 10 years since I last had it out of the tank.
- Justin Kerns
- Thank you received: 8
phpstack-1081784-3880776.cloudwaysapps.com/html/join.html
I also recommend you buy the club Newsletter DVD. It has searchable pdf files of all club newsletters back to 1952. You can search for your car and find all technical articles that have ever been written. You can order this and other great items here:
shop.phpstack-1081784-3880776.cloudwaysapps.com/
Justin
Justin
1932 Auburn 12-160A Sedan
1933 Auburn 12-161A Sedan
auburn653 wrote: Is pickup tube diameter only difference between SC, 8 cyl, 6 cyl ? Don't they all use the same tank (34-36)?
The s/c fuel line is 5/16 OD all other cars are 1/4 OD. All fuel tanks are the same size. The speedster has a different P/N because the filler neck is different. The fuel pickup / telegage sender has a different P/N as well, due to the female fitting on the fuel pickup line.
auburn653 wrote: 3435A would be a non-supercharged Sedan, frame number 2435.
if frame 435, and supercharged, wouldn't it be 31435A?
Curt, can you confirm?
yes
- Rogerlearmonth
- Junior Member
Being completely new to Auburn ownership, I?m certain I shall be back many times, cap in hand, to beg further information.
Roger
- auburn653
- auburn653
- red.auburn851
So is the numbering always like that. My number is 3435A. Does that mean 3 plus the 435th made?
Marcus
Rogerlearmonth wrote: Thank you Mark, I'd be very grateful. Do you perchance have a tank unit for sale?
On a different topic, we are about to take off the paint today and I'm as nervous as a kitten as I think my chassis no seems to be one of the earliest around (32910E) and I'm very concerned about disturbing the lead on the body tub (if it?s there).
Roger
Your serial number on the dataplate equates as follows :
The first 3 designates a supercharged car
the 2910 is the 1,910th 851 to come off the line in 1935 out of a total of 2986. The number on the dataplate is 1,000 more than the frame number.
I sent you an email.
- Rogerlearmonth
- Junior Member
Roger
- Rogerlearmonth
- Junior Member
Thanks for the response, I won?t get into a semantic discussion but I guess we all know what I mean. The tank unit sends information about the fuel level to the gauge. I?m not sure that the fact it does so hydrostatically as opposed to electrically is relevant. In any event I have been offered a unit for a Duesenberg and wonder if it can be adapted for an 851 SC Auburn. Any images or dimensions would be appreciated. I believe that Ford used a similar device.
- Rogerlearmonth
- Junior Member
Thank you for your help.
Roger
