speedometer cable noise
- morrisgauge
19 Jul 2015 03:41 #29925
by morrisgauge
Replied by morrisgauge on topic Re: speedometer cable noise
I would recommend removing the cable to clean the core and housing, then checking the core for kinks before lubricating with a light lithium grease or one of the commercially available cable lubricants. You need only lubricate the first 2/3 of the core as you insert it into the housing to prevent over lubrication.
www.morrisgauge.com
www.morrisgauge.com
15 Nov 2010 10:34 #18398
by ilikescars
Replied by ilikescars on topic speedometer cable noise
I used "Slip Plate" graphite coating. It goes on kinda like a paint. Purchased from McMaster Carr. Works very well.
15 Nov 2010 00:01 #18389
Replied by mikespeed35 on topic speedometer cable noise
Beware using to much lub. It will wick into the head of the speedometer and cause faulty readings.
- Neal Ziff
14 Nov 2010 03:40 #18388
by Neal Ziff
Neal
_________________
1930 8-95 Cabriolet
Replied by Neal Ziff on topic speedometer cable noise
thanks Tom - I'll check at my local NAPA
Neal
_________________
1930 8-95 Cabriolet
13 Nov 2010 23:29 #18387
by Tom Georgeson
Replied by Tom Georgeson on topic cable noise
Auto part stores have a lubricant in a tube for this problem. I think it has some grahpite (?) in it.
- Neal Ziff
13 Nov 2010 19:51 #18386
by Neal Ziff
Neal
_________________
1930 8-95 Cabriolet
speedometer cable noise was created by Neal Ziff
My speedo cable makes a horrible noise periodically. I can sometimes stop it by reaching under the dash and adjusting the shape of the cable. I have disconnected it from the gauge and used 3M light weight oil (sewing machine oil) in it, but it does not eliminate it entirely.
Is my problem lubrication, or the type of lubricant - or perhaps something else?
Neal
Neal
Neal
_________________
1930 8-95 Cabriolet
