Auburn wire wheels
- samsonized
17 Jan 2004 12:32 #1207
by samsonized
Replied by samsonized on topic lock ring wheels
hi lloyd its mike samson hope the weather in california is good. give me a call and i will help you through changing the tire 219-771-6453
- Lycoming-8
17 Jan 2004 05:24 #1206
by Lycoming-8
'31 Auburn Coupe
Replied by Lycoming-8 on topic Auburn wire wheels
This thread should appear in the Auburn section, but until it is moved I will suggest that the ring can only be safely removed if the tire is fully deflated. Do not attempt to replace it back on the wheel and air a tire up on your own, if you do not have a "cage" for doing this work!!!
'31 Auburn Coupe
- lloyd riggs
16 Jan 2004 21:15 #1202
by lloyd riggs
Auburn wire wheels was created by lloyd riggs
Help fellow club members: I have my first Auburn, a 1931 model 8-98 that has wire wheels. I am attempting to change a tire and am unable to remove the split ring. Is there a secret to this operation or is there a special tool that one is to use. I would appreciate any information and help that any member cares to pass along. Many thanks. lloyd riggs
