1935-36 Supercharger
- Lee
19 Dec 2005 06:00 #4146
by Lee
think driver; look at others
Replied by Lee on topic Curt, did you find the routing of the cooling (warming) syst
Hey Curt, how you doing? Did you find the exact design for the s/c warming water pipes? it is my understanding this water was to warm up the gas in the S/C, not cool it and isn't really necessary. Anyway, i was wondering if you got the exact design. the ones on my car are touching the exhaust manifold, thus heating the water more than I would like. Did the original design go close to the exhaust manifold? Thanks Lee, <a href="mailto:[email protected]][email protected][/url]
01 Mar 2005 12:38 #2914
Replied by Curt Schulze on topic 1935-36 Supercharger
I have enough 7/16 soft copper tubing to do a lot of superchargers and dual ratios. Are the superchargers cooling lines flair fittings, or do they have a ferrule that was sweated on. Since I have quite a few of the original fittings, I would like to make it as original as possible.
Were the S/C lines and fittings natural or cadmium plated?
- Auburn/Cord Parts
18 Feb 2005 14:45 #2880
by Auburn/Cord Parts
Replied by Auburn/Cord Parts on topic 1935-36 Supercharger
I have a schematic of the Auburn supercharger unit. We have tolerances that we've used successfully for many years. The original cooling lines were 7/16" and no longer available - you can use 3/8 or 1/2 inch with
modern fittings. We can show the oil supply and drain back lines. There is not a lot of factory data and most is not that good.
Stan
Stan
16 Feb 2005 18:43 #2865
1935-36 Supercharger was created by Curt Schulze
I recently acquired a "basket case" 36 S/C cabriolet. This supercharger is a new ball game to me. Is there a recommended tolerance checkout, rebuild procedure? I have no cooling or oil lines. I need info on correct line size and routing. Is there a blow up diagram for the supercharger, much the same as thre is for the convertible tops?
